dumb resin question
glenn property of pam
i tend to over think things which is why i need to ask
epoxy will bond to a poly hull. poly will not bond to epoxy. isnt that a oxymoron or is it wet poly can not bond to dry epoxy but wet epoxy can bond to dry poly.
tpenfield
Re: dumb resin question
poly does not have good bonding characteristics . . . So, you might get poly to bond to epoxy, but it will be a 'temporary' bond.
Epoxy has good bonding characteristics, and is used for a wide variety of bonding applications.
but why do you ask the question - out of need because your in the middle of a project and trying to determine the route of epoxy vs poly, or out of curiosity for your own edification?
curiosity...................its the oxymoron that gets me. if one wont bond to the other then other shouldnt bond either unless.........
Ayuh,... That's the just of it, Yes...
jigngrub
Epoxy is an excellent adhesive.
Polyester is good for... oh, I don't know... womens dresses and unmentionables and such stuff.:p
