Duo-Prop / Bravo III / Bravo I question
bear_69cuda
Good morning,
If I needed to re-power a boat that currently has a 2000, Volvo 7.4 Gi with DP, to a Mercruiser engine (350 Mag or 7.4 MPI) with either a Bravo III or Bravo I drive, will the transom bolt holes, and outdrive hole match between manufactures? I'm just curious for the future....
Thanks in advance!
Re: Duo-Prop / Bravo III / Bravo I question
Ayuh,... I believe Volvo had gone to the standard cut-out by 2000....
Friscoboater
Ummmm is there a new project in the works?
