Tafflad
Thread starter- Joined
- Oct 23, 2007
- 548
Have a bowrider with a VP 280-C DPS
For this motor the WOT range is 5400-5800
The prop set has to be changed under warranty, due to corrosion on the SS blades.
The dealer did some test runs with new prop set (original pitch)
And with a set with next pitch down.
The results are ...
Original pitch prop
Max speed 48.8 @ 5560
3040 - 24.1mph
3560 - 29.4
4080 - 38.5
New Prop. (Down 1 pitch set)
Max speed 47.3 @ 5800
3000 - 21 mph
3580 - 27.9mph
4000 - 31.8mph
4570 - 36.6mph
VP Dealer recommendation is to go with lower pitch as it has better pick up, but stays in power band limit.
My use is towed watersports most of the time around 18-22mp
What do you think ?
The results are ...
Original pitch prop
3040 - 24.1mph
3560 - 29.4
4080 - 38.5
3000 - 21 mph
3580 - 27.9mph
4000 - 31.8mph
4570 - 36.6mph
What do you think ?
