Durban tests heat sensor
durban
many of us overlook this very important liitle sensor , we take cylinderheads off & repair everything else but this little thing : gets overlooled : uploaded is a photo of where ists located , & upon removeing note the rust on the surfaces , i put my soldering iron on it without cleaning it , & thermometer on it to check the temp .& connected the meter to see if the circiut is working
well the heat went up to 104degrees nothing happened , i then cleaned it up & repeated the prosess , it was barely 2min & the meter showed the circiut closed , then i knew it was still working ,
the point iam wanting to make is that if i left it without checking it with all that rust in between the surfaces & a problem with the water circulation while out onthe water , you already know the results , cheers:joyous:
http://forums.iboats.com/non-repair...-cylinder-head-temperature-sensor-589871.html
