Re: durbans heat resistant epoxy formula
motor doesnt get near to this heat so i wouldnt worry about it
Two-strokes generally run best when the exhaust temperature (measured approximately 3 to 6 inches from the block exhaust port) falls between 1150 and 1300 degrees Fahrenheit at wide-open throttle (WOT). Partial throttle readings will typically measure quite a bit less. A well-tuned outboard usually shows temperatures in the 700- to 800-degree range at idle to off-idle speeds, climbing to about 850 or 900 degrees in the midrange, then finally to about 1200 degrees at three-quarters to full throttle. Source for this information and guages below....
Digatron Instruments
Dept. BWB, 8102 North Freya St., Spokane, WA 99217 509/467-3128 digatron.cc
Exhaust Gas Technologies
Dept. BWB, 1381 N. Kraemer Blvd., Anaheim, CA 92806
800/348-4678 exhaustgas.com
Gaffrig by Livorsi Marine
Dept. BWB, 10 Gaffrig Drive, Grayslake, IL 60030
847/548-5900 livorsi.com
Hewitt Industries
Dept. BWB, 5492 Bolsa Ave., Huntington Beach, CA 92649; 714/891-9300 hewittindustries.com
Hydro-Dynamics
Dept. BWB, 1 Hydro Lane, P.O. Box 418, Benton, LA 71006
318/965-0201(no website)
Nordskog Performance Products
Dept. BWB, 1120 Yarnell Place, Oxnard, CA 93033
805/483-2411 nordskogperformance.net
Racepak/CSI
Dept. BWB, 30402 Esperanza, Rancho Santa Margarita, CA 92688; 949/709-5555 racepak.com
