i bought this for 100 dlr i plan to convert it to a sea boat , building a stand up console & will be looking at increasing the draft \displacement around the transom area as i would be fitting one of my 70hp or 60hp Johnson \Evinrudes on the transom , iam a bit concerned about water coming over the transom with the weight of the motor & 2 , 25ltr fuel tanks . ive got a plan in my head , to weigh the motor & all the gear fill sand bags put the equivalent weight on the boat & then place the boat in the water then mark the displacement line where the water will be on the hull , from that line i want to build some pontoons around the stern area on port & starboard side of the hull below the water line & on the inside of the transom build a scoop that will catch water coming over the transom & drain out through holes in the transom again , this is only a 3.8 meter boat , also a water tight deck the seats that are fibreglassed in i will cut out & fit 2 swivel seats .
Any plans & advice would be appreciated , i will more than likely fit this motor
http://forums.iboats.com/showthread.php?t=527612
