Sea Rider
- Joined
- Sep 20, 2008
- 12,345
If suspect there's water intrusion in the lower cylinder, the plug's tip should look rusty after some run hours at open water, how much rusty, will depend entirely on how much water entered that particular cylinder. Assume that head gasket has not been re torqued to specs since new, right ?
Why isn't the standard NGK spark plugs Yam calls for not being used, those plugs are ideal to be run at constant high rpm, say when cruising for long time periods. A matter to check which ohm meter model was used at the factory, which surely differs from the one you used. Yep, not much out of factory specs...
Happy Boating
Happy Boating
