Re: E-10 for science minded people
Usually.
The ethanol is suspended/mixed with the gasoline. Water mocules are absorbed/bonded with the ethanol.
When enough water gets absorbed in the ethanlol, it will "phase separate", from the gasoline and settle on the bottom of the tank, as water by itself would normally do. This is where an installed water separater, would draw of small amounts the water/ethanol mix.
If I read you right, the haze in the fuel is actually saturated ethanol?
Usually.
