E-tec 90 or E-tec 115
mailman1
I have an 18 ft Winner center console that weighs in at 1850 lbs dry. I now have a 140 1987 Suzuki on it. Would the 90 or 115 be the one? I do not care about speed, just get up on plane and cruise around 30 35 mph. Any help? The boat came with the 140.
marinemech1
Re: E-tec 90 or E-tec 115
the e-tec 115 won't be avaiable until june sometime its going to be a v-4 so extra cubes may be a benefit<br />the 90 preforms well and is readily avaiable<br />also if purchased before april 15 7 year warranty may be avaliable to you see your dealer<br />so its up to you<br />hopes this helps
steelespike
Most boaters become disappointed when going with smaller horse powers.I would hold out for at least the 115.
cobra 3.0
Once you have tasted more, its difficult to go back. I dunno...You will be spending as wack of dough...a larger motor is more than just speed. It's the overall feel during actual driving/boating. You will be working the smaller engine a lot more...higher reving, probably more noise because your pushing it more...less performance. If you end up adding few people once in a while, the differnce will shock you.<br />In a different smaller boat...maybe, but you will be making a very direct comparison in an engine change. The techology will not compensate for horsepower.
jegervais
I'm inclined to agree with steelespike and cobra. If your boat is rated for 150hp, you may even want to consider waiting for the 150 E-TEC.<br /><br />The larger displacement engine doesn't have to work as hard to plane a boat, keep it on plane or cruise. <br /><br />Although the effect on longevity is negligable, generally fuel economy is usually better with the larger engine because it can run at a more efficient rpm to maintain the hull on plane, while a smaller engine typically has to turn more rpm to maintain an adequate power level to keep things happening.<br /><br />For example, when I first bought my 19' Lund (with a 150), I met another owner who had the same boat with the 115 cross-flow V4. Where I can keep my hull on plane at 2000 rpm, he had to be over 3200 rpm to stay on plane and generally had to run 3/4 throttle or higher just to cruise. Top end was about 32 mph with the 115, while with the 150 its 53-ish. I don't run there (53) much, but its nice to have when you need it.<br /><br />BTW the Lund hull weight dry is about 1300 lbs.<br /><br />-John
bossee
Hi,<br />Why not a Suzuki DF140 4-stroke?<br />Light, powerful, quite, EFI(=fuel efficient, easy starting etc), not that expensive.<br />Or a Johnson 140 4-stroke (it is the same outboard as Suzuki DF 140).
