jimbobcooter
Thread starter- Joined
- Feb 27, 2012
- 78
I have a 94 Evinrude E120TLERC. We were out on the lake today for about 4hrs. She ran great until we went to run home. We idled out of the cove we were in and then cranked her up to about 80-90% of WOT. After about maybe 3-5min a continuous alarm sounded. My brother was driving so I told him to shut it down immediately. He came to a safe stop and shut the engine off and the horn stopped. When I put the key back in the ignition and turned it to the on position the alarm sounded continuously again. When I pulled the cover the starboard side had a tacky liquid on it b/w the two plugs (not sure if it was oil or paint from the head).
After using the trolling motor to get back to the dock (~15-20 min) I tried starting the engine again. No alarm and water from tell tale. Shut it down Retrieved the trailer from another launch (~30-45 min). Decided to let it idle for a bit at the dock before leaving. No alarm and the port head seemed to get hotter than the starboard. I let it idle for a good 5 min with no alarm. I let it continue to idle while I backed the trailer in. With still no issue I took it for a quick spin to get her up to speed. Maybe a 5 min ride with no alarm or noticeable change in performance.
I am thinking this is an overheating issue, but I would think that it would have repeated. Could it have just been some trash that was blocking the intake grate? When the alarm initially sounded we quickly raised the engine and there was nothing around the intake on the lower unit.
Note: Water pump was changed this past winter. Carb cleaning planned for this winter as I have had some coughing at idle. Oh and this debacle http://forums.iboats.com/forum/engi...weak-out-of-the-hole-evinrude-e120tlerc/page3
