rowerowe101
Thread starter- Joined
- Aug 4, 2019
- 92
I picked this bad lad up and went from a stuck starter solenoid and no spark to getting spark on 2/3 off the cylinders, allowing to run at 1/2 throttle and up but immediately cutting out at idle.. almost before I even fully bring throttle back to neutral. So I suspect air leak. Pressure test fuel system and determine pump and carbs are not holding pressure . I’ve ordered a rebuild kit for pump, and have already rebuilt the carbs but I’m a bit stumped with them; adjusted float ; made sure brass fitting all the way in,
Inlet fuel hose tightened as much as possible,and that everything has been replaced/installed properly in general but they still won’t hold pressure … any idea what is going on here? The float should rise and shut the needle/hold pressure when I pump my pressure guage right ? Also is the nozzle gasket completely necessary for operation ? Seems kinda useless just sitting on the top of the nozzle..
