dawgsfootball
Thread starter- Joined
- Jun 27, 2008
- 5
I recently mounted this FF, I put the transducer on the low end of the hull away from the motor. The thing I don't understand is the transducer after being mounted goes up and down almost completely vertical, the directions say not to tighten the nut to tight so that if it hits debris it won't just snap off but it seems like when I take off the transducer is going to be lifted straight up instead of horizontal to the water. Ant suggestions, is this the way it is supposed to be? Thanks for the help.
