Eagle Z-9000
Status
Not open for further replies.
petryshyn
Can anyone tell me if there is a common failure with the back-lighting in a Z-9000 sonar?<br />
Best boating!!
12Footer
Re: Eagle Z-9000
Are you sure it is the backlighting? Is the<br />screen blacker than normal when the unit is off?<br />These LCD screens turn black when left out in the sun. Sometimes, you luck-out and it comes back,sometimes, it is toast. If only one half of the screen elluminates, it is the lightbar on that side. They are a bugger sometimes too replace, but they can be purchased from Eagle.<br />If the entire display is weakly lit, it is a low volt condition. The display will be the first to quit as the battery fades.
petryshyn
Re: Eagle Z-9000
Hi 12footer. The unit has internal bulbs all around the LCD display. The bulbs check good but don't come on when you select night light. I contacted Eagle but they seemed more interested in selling me a new one rather than talking 'repairs'. Seems the circuit that turns the bulbs on is intigrated with the large onboard processor. I was hoping to find a miracle cure!! What do you think??! :(
12Footer
Re: Eagle Z-9000
Does this unit have the "membrane" type of panel? Or does it have actual switches behind the faceplate?<br />If you can, remove the faceplate to get to the back side,where the contacts are (it will look like a printed circuit board.<br />Take a pencil eraser.and rub these contacts until shiny. Believe it or not, I think this is all that is wrong with it....Provided ALL the lights do not function to begin with.<br />My Uniden VHF radio had this type of contacts. Use the eraser on the back side of the button too. It really does work,as ridiculous as this sounds.<br />If cleaning the contacts does not restore it, I'm afraid it may be cheaper to replace the unit.
petryshyn
Re: Eagle Z-9000
You know...thats a darn good possibility. It does have a membrane touch pad!! I'll give that a try....<br />Thanx 12footer :)
mikew5432
i can't understand why i can't find these anywhere but here, i bought a boat with the eagle z 9000 but didn't come with instructions
anyone know where to find a copy of the instruction manual as i've tried seaching with no luck.
Status
