early 50s gale recoil
JasonAych
I have a 53 Sea King recoil I need to repair. Pulley is bent in and rope will not feed in. Same as lightwins from that era.
I took the center screw out and lifted it carefully and saw the sping was coming with it.
Question is do I continue? Is the spring going to go back in?
JasonAych
Re: early 50s gale recoil
Are you surmising or are you talking from direct experience with this type of recoil?
I already surmised what you stated.
Thanks.
1946Zephyr
The little cup you are lifting out has a pin on it that is on the end of the spring. You can pry it off with a screw driver, before it comes flying out of the housing,........hopefully.:cool:
