Top of the morning guys. Just putting a post in here to see if anyone has had a similar problem. I just redid a paint job on my early 70s IMC Tri Hull. Boat turned out awesome Ima post sum pics in the painting section.
Anyways onto my question. I had to take the motor off for painting so I disconnected everything...and let me say the boat ran great last year. Its an early 70s 85HP Mercury Blueband with Thunderbolt Ignition So today was my official launch day but once I got it in the water I couldnt get her to start. It would crank but as soon as she got close to starting the starter would disengage. When I use the spark advance lever all the way forward I could finally get it to start and it would rev up like crazy but as soon as you dropped her into gear there was zero power and if you even LOOKED at the choke button it would quit. At full throttle I was doing about 5mph... So my question is do I have a carb/ignition problem or did I screw something up when I reconnected my cables?
