Hi
For the last 6 months, I have been refurbishing my old flat bottom jon/bass boat conversion. I finally got to the engine. After removing both carbs and giving them a good cleaning, I tried starting the engine. I made sure that the cylinders were lubricated before starting. I got it running. It will not idle though. I looked at the ignition switch box and noticed that one of the wires was corroded and broken. I traced the wiring under the top carb and up to where it disappeared under the flywheel. It looks like the wiring connects to the stator. I thought I could splice the wire but it was too corroded. My question is two parts. Would the broken wire cause the engine to not idle? It appears to relay to another wire that carries voltage to the top sparkplug wire. Also, will I probably need to replace the stator? I haven't removed the flywheel yet to get a look. I need to find a wheel puller.
Thanks.
Thanks.
