Early Bayliner Tri-Hull
mike165
Where would I look for I.D. on an early Bayliner Tri Hull possibley built around 1978-1982 20' 165 6inline Mercruiser.
The HIN was issued in Australia in 1996
etracer68
Ensign
Re: Early Bayliner Tri-Hull
If it has one, it should be, upper, outside, starboard, transom. (Upper, right, on the back outside). The last two numbers generally indicate the year.
tpenfield
Usually the HIN is molded into the hull at the time of manufacture and not 'issued'. Perhaps you could post the number that shows on the upper starboard area of the transom.?
mike165
Thanks for the replys,the boat had been sprayed with auto enamel!! which has been removed,and refinished with marine polyeurathene during which it was examined for any numbers in the glass and none were found.I will post some pix.What years did the HIN's start in the USA?
mike165
Upload pix
The bow and stern rails are all stainless with welded joints which I am told is unusal for Bayliner they seam to be original
tx1961whaler
HINs became required for boats in the US about 1971-72. A 1978 boat would definitely have a HIN.
sqbtr
My '76 has the HIN molded in the transom port side it is also stamped in the rub rail port side aft.
mike165
Maybe I am the wrong track with this,when I got it 2 years ago it had the Bayliner name on it in stick on letters and on the rego papers, it had a 20 gal fuel tank in each side at the stern,there was a tag on each tank "1980" made in the USA,it had a Type 1 or R outdrive which I have changed to a MC1,the motor is a 165 Mercruiser which looked to be original,HIN did not start in OZ untill mid 80's maybe it was built in Australia,the plot thickens!!!!!
