Reggie08
Thread starter- Joined
- Mar 31, 2008
- 243
I'm nearing completion of a powerhead rebuild for an 85 'Rude 90hp. I just have a few things left to do (install t-stats, rebuild carbs, install cylinder head, etc) but before I tighten everything down and get it all put back together, I'd like to know if my compression is good. If the compression is weak, I know I have a leak somewhere I need to fix. Is there a way to check the compression other than having it hooked up to a battery and turning the key? Would turning the flywheel with a socket produce reasonable/comparable results?
