Jconnell43
- Joined
- Sep 4, 2005
- 85
1.When they say at idle your timing should be 4 degrees below top center should I be using the 4 marked on the flywheel or using the scratch mark I made on the flywheel?
2.If I have the timing correct but the cam follower and roller disconnected should the engine run or do the butterflies have to be completely closed when they are not being opened by the cam roller.
Thanks,
Jim
Thanks,
Jim
