Eaton m45 3.0
Status
Not open for further replies.
mittimj
Just a reg heated o2 sensor and the gauge has the smarts to make it work. Was 150$ or so
mittimj
No Title
mittimj
Robbed this off the drag car to try. Set initial timing to factory spec and this will pull up to 3 deg per pound.
aiming to re install my 10psi pulley without top end detonation.
Very nice, but think the whine would get to me after a while,
mittimj
The charger wine is ear piercing loud lol. For what I'm using it for I love it. The engine compartment has never been sealed up good on this boat. I'm sure I could quiet things with some insulation
mittimj
Boats all winterized till spring. Brought it up to 50mph one last lap around the lake. Seemed to perform same as having 3 ppl to one guy.
I think I'm pushing the engine a fair bit past its peak hp curve. Falls off after 47mph or so.
Plan is for spring time to do a 21p prop and I would like to see it at 10 psi.
Or maybe pick up a 19 stainless and just lift a little when it's to max rpm
Ayuh,.... Pretty Cool,..... What rpms ya runnin' at those speeds,..??
Speak
Love it man!!! The whine would drive my wife nuts! Lol - prop it up and see if it hits 55mph - have u crossed your speado with a gps ?
mittimj
Rpm.... Well allot. Tough to put an exact number on it due to glitchy tach.
All speed runs have been gps. Speedo isn't to far off. Maybe 3mph either way depending on which way I go on the lake.
50 mph was my goal. I'm not sure just how far this engine will hold.
Starting to warm up outside. Will have to get it back in the shop.
Plans are to fab up a auto tension settup for the serp belt.
Like to quiet the intake. Maybe a rubberized coating.
Occasionally the engine will flood on startup. It would be nice to have a electronic fuel shutoff valve. The temporary solution was vice grips on the fuel feed line. Effective but crude.
In general going to try making it a bit more user friendly.
mittimj
No Title
Picked up another motor to play with / spare unknown year. Hoping that's it's same as mine
Steve390Gold
To the top!! Love the build!!
Did you drill your two pilot jets or the singular large jet on the bottom? What size orifice would you guess they are now?
Aside from the timing retard box, id suggest some studs to keep the HG in place!! You singularly proved this engine is a beast despite the naysayers!!
Status
