LadyFish
Thread starter- Joined
- Mar 18, 2003
- 6,894
Effects of ethanol on outboard engines
Galveston County Daily News
By Joe Kent
Correspondent
Published September 10, 2006
If you looked outside Saturday, you would understand why there were no fishing reports. Friday, prospects were great for a good weekend for anglers, then Whammo! The storms hit with a fury about noon Saturday, bringing fishing to a halt.
This presents an opportunity to pass on some vital information about the adverse effects of ethanol on boats with outboard engines.
Before beginning, however, I want to thank my longtime friend Marie Brocato, a weekend resident of Galveston and career salesperson in the boating industry, for furnishing most of this information.
Ethanol 10 is now the only gas available and, albeit potentially beneficial to the environment, the effects on outboard engines can be disastrous. Ethanol does not store well without a stabilizer. Even so, ethanol stored in fiberglass or plastic tanks will make the fiberglass soft and mushy, leading to tank failure and engine failure, due to the plastic or fiberglass dissolving into the gas.
Ethanol is an alcohol and absorbs water. Prior to the introduction of ethanol, water would drop to the bottom of the tank. With ethanol, water is absorbed, which, in turn, will contaminate the whole tank of gas. Boat gas tanks are more susceptible to water, and the ethanol blend will absorb water from the air as well.
Ethanol is a solvent and will deteriorate rubber hoses and fuel lines. It will also remove sludge and grime from the walls of the tank.
Now, what should the boater do?
First and foremost, contact the manufacturer of your engine or dealer. Most all of the outboard manufacturers have newsletters and other information on how you should deal with the new gasoline. Also, discuss it with your outboard mechanic.
If you do not have a water separator on your fuel line, make it a high priority to get one.
Keep a stock of water separator filters on the boat, together with the proper tools to change them. There are numerous other suggestions and your boat dealer or mechanic can fill you in regarding your specific engine.
By Joe Kent
Correspondent
