EFI conversion?
mommicked
Newbe here, have seen alot of opinions on ethanol problems w carbs. do EFI motors have the same issues,and is it possible or feasable $$ to convert a 03 90 4strk to EFI?
robert graham
Re: EFI conversion?
Fuel,ethanol,water,dirt,varnish,etc. are problems for carbs as well as injectors. Install a fuel/water separator, use Stabil Marine all the time, try to maintain clean, fresh, stabilized fuel all the time. Drain carbs on a regular basis. Good Luck!
