EFI Problems
Flbob
I have a DF90 4 stroke EFI which has only 20hrs on it. It has not been run for a couple of years and will not start. I suspect clogged injectors may be the problem. Since it won't start I cant run cleaner thru the engine. I have attached a portable tank with fresh gas. Is there a method to clean the injectors out of the engine? or while still installed?
Sitting by the dock of the bay : (
