Re: EFI Upgrading Questions 87 2.3
Well, the cheapest (not 100 percent legal) is to get an efi setup off of an automotive 2.3 and convert all parts over. This would include the wiring harnesses, sensors, and connections. The next step would be to flash/retune the computer to work with the cams installed in your boat for marine use. This would tune in all fuel/ air ratios. Make sure you get a sealed distributed cap, use dielectric grease on all connections, and install an out of tank high pressure pump/reservoir for fuel demand. Unless you have hardware/software to tune the efi computer in, you will lose reliability and efficiency changing it over. Try telling the computer you midrange powerband through 4-5 gears just changed to a one gear low powerband without changing fuel demands. All parameters shot (especially with no o2 senso to assist in the tuning.
