Elbow from water jacket
OtterRidge
Does anyone know what the size of pipe threads are on the nylon-plastic elbow that comes from the water jacket on a 1998 Mercury 60hp. 3 cyl engine and connects to the hose that goes to the tell tail? Also would there be any problem by just using a straight pipe nipple and going right through the casting and bypassing the hose and elbow? The reason I have thought about going that way is because I run in the Missouri river with a lot of sand and with the elbow it has a habit of plugging up but with the straight pipe it could go straight out of the engine with les chance of plugging.
Fun Times
Is the elbow that's there on your engine a 45 or 90 degree turn as there seems to be 2 sizes listed....Item number 38, http://www.mercruiserparts.com/bam/s.../28191/571/150
For sizing, The below info is the best I can find as far as actual listed sizes.
FITTING Elbow 45 Degree (1.25) (#22-782792), http://www.ebay.com/itm/NEW-Mercury-...-/121538096654
Elbow 90 Degree (.125-27 x .250) 22-996642, http://www.crowleymarine.com/parts/4977.cfm
OtterRidge
The elbow is a 90 degree and there is where the problem is when you happen to get into sand it's hard to get the sand & water around the 90 degrees without pluging. up the line.
OtterRidge
Thanks for the reply's I think I've got the problem solved. Rethreaded the fitting and seems like it will work fine. I don't use the form much but every time I have I have found out what I needed to know. Thanks again
