I have encountered water in my oil and am trying to find the problem asap. time is limited. shorts summers and long weekend coming.
The engine is a 1999 merc 350.
Last time out she was running fine and just died. She would not idle but did run when the trottle was opened up about 1/2 way. Then we noticed water in the oil but not a large amount.
One engine builder told me if the the spark plugs are rusty then water got into the cylinders. This is not the case. However i was wondering if a small amount of water was getting into the cylinders then this is why it would not idle, but when giving her more throttle the fuel out ratioed the water.
I've read the risers/elbow gaskets could leak and let water back into the valves?
Sooo i took of the elbows. see pics. They seem ok BUT can someone confirm?
My next question is can the exhaust manifold gaskets leak the same?
also she slightly overheated the prior time out. maybe 210 degrees for a small time. which is probably the water/oil problem now.
