elect choke on carb
ambush68
V20 mcm 3.7 242 cd 165 hp
The diagram I have shows from choke bottom screw to gnd . gnd? I have purple wire to choke but didn't have a gnd before i had it rebuilt..
UncleWillie
Most Choke Heaters are grounded through the Carburetor to the engine.
It is hard to image that the carburetor is not electrically connected to the engine block.
Try it without the dedicated ground, if it does not work, add the ground connection to the choke.
ambush68
carburetor is not electrically connected to the engine block.? wow that's confusing to me sorry, did you mean carb or choke?
carb is metal and its bolted to the metal block that's bolted to the battery dc negative cable so the carb is ground. So one wire to choke coil 12v+ and the body of the carb acts as ground. If that doesn't work then add another wire to the choke to a know ground point.
