Seapilgrim
Thread starter- Joined
- Aug 17, 2012
- 6
I am having a problem with the passenger side wheel on my single axle trailer overheating. The wheel and the axle are too hot to touch after only driving 12 miles. Here is some background information.
The bearings and brakes (electric) were changed last year. After a recent trip I noticed the passenger side bearing protector cover missing and upon further investigation found the hub and wheel too hot to touch. I examined the driver side wheel only to find it to be cool in comparison.
What I have done so far to find the problem:
I unplugged the electric brake controller in the vehicle. The problem still remained after a test drive.
I jacked up the trailer and spun the wheel and could not hear or feel any dragging. I then removed the wheel and hub only to find a significant amount of what appeared to be a black graphite type dust on the inside of the drum. I believe this is from the brake shoes but not sure how much is normal. The rear brake shoe appears to be wearing more than the front brake shoe. The surface of the magnetic puck is slightly worn so it appears to be making contact with the hub which I understand to be normal.
1) Why would the rear brake shoe be ?dragging? enough to wear yet is not noticeable when on the jack and spinning the wheel by hand to adjust brakes?
2) Was unplugging the brake controller the correct way to disconnect electric brakes for testing or should I have unplugged the trailer wiring from the vehicle?
Any ideas on where to go from here would be appreciated.
Thanks,
Bob
Thanks,
Bob
