Re: Electric Choke
I assume you have the pull up manual choke lever like the older classic 4 cyl. Go to a marine dealer that has been in business for a long time and scrounge one off an old engine. The carburetor is probably setup to accept the linkage of the auto function.
On my control box, the choke wire is a yellow wire with a black stripe. It should be in your engine wiring harness as a loose wire adjacent to the connector. With the switch on (probably need it on) pushing the choke button will put 12v on this wire. If your color code is different, look around the engine for a loose wire from the engine electrical harness and test them till you find one with 12v on it when you push the button. The case of the choke grounds to the engine block.
That ought to work,
Mark
