Electric fuel pump conversion
jdogonhood
I replaced my cracked 88' 4.3L with a used block, however the newer block is not drilled for the mechanical fuel pump. Can anyone tell me what electric fuel pump will work best and hopefully bolt right in? please and thank you....
drem312
Re: Electric fuel pump conversion
I just put on my 5.7 a carter marine electric fuel pump with there oil pressure safety switch had to adjust the bracket but it works great
jdogonhood
Sweet. Thank you. Do you remember the part number? Where did you find it? How much should I expect to pay? I really appreciate the info....
drem312
Carter marine pump is around 100 bucks the switch is like 17 I think the part is like 4389 something like that
