Jonezin1
Thread starter- Joined
- Oct 27, 2018
- 10
I
I have a 93 marine power 350 sports pac carbarted
I made the manual fuel pump conversion to electric.
I'm running carter's low psi pumps 6-8 psi
I've installed a 3 prong oil pressure safety switch.
I'm running a 40amp relay
On the pressure switch they are labeled
P
S
I
S being the connection that comes from the starter yellow/red wire.
Here's my question,
Should the "S" wire (yellow/Red) be contently hot with key in the on position?
My problem is, when I turn the key to on to prime, pump doesn't run
Pump is new if i supply 12 volts independently it works. Im going to attach my wiring diagram. Please advise if its wrong
P
S
I
Here's my question,
