Electric Horn Hook Up
golbrick7
Want to add an electric horn to my boat with a momentary push button switch. Is there a simple way to do this?
oops!
Re: Electric Horn Hook Up
yeppers.........simple....hook a battery to your babe and push any button you want. !
lets get this moved to the electrical dept.....and iboats will have you honking and hooting in a jiffy
5150abf
battery + to one side of switch, from other side of switch to horn +,then wire from battery - to other side of horn and you are done.
Now, all boats are a little different, you may have a power block or everything may wired directly to the battery so where you pull your power from might change but that is how you do it, very simple.
Alot of boats have a main buss, positive and negative power from the bow to the stern that things branch off of so may be able to tap into one of those but without actually seeing the boat no one can tell you exactly where yo get your power from.
Maybe google "basic wiring" and get some education before you start, a 2 wire switch is pretty basic.
Also check your local regulations before you mount it, were I am a horn has to be open to the air so you can't put it under the console or anything like that.
golbrick7
Thanks for the help and advice. Got it working just fine.
Go OU!!!
NYBo
5150afb left out the fuse between the battery and the switch, as close to the battery as possible.
