reelfishin
Thread starter- Joined
- Mar 19, 2007
- 3,050
I was given a 1971 50 HP the other day along with a set of single cable/pushbutton controls. The motor was taken off an old boat that had sat for about 35 years or so in a barn. It has 130 pounds of compression on each cylinder and looks pretty clean. The throttle cable is shot and someone cut the wire harness about midway to make removing it easier.
My question is, are these as bad as they say? I have an older boat that this would be perfect on but don't want a headache motor. Is there a way I can check the shift solenoid to see if it all works before investing any time or money in this?
So far everyone that has seen it agrees it's clean for a 1971, but I've been told over and over to junk it and find a non electric shift motor.
Also, there's a micro switch on the throttle cam that has no wires on it? The boat it was on was destroyed by a falling tree, thus why I ended up with the motor, but the motor was well protected and didn't suffer any damage. I didn't remove the motor, it was pulled from the boat by the owner and sat in his garage for a few years as well since then.
I have no other experience with any electric shift motors, so any input on this would be very helpful.
