salvageyard saviour
Thread starter- Joined
- Oct 28, 2018
- 170
Just curious,
I recently took apart a high profile 225 - 245 HP drive for parts and found the water pump shaft and the upper shaft stripped.
In a past thread Howard Sterndrive mentioned this as common but didn't explain why.
What causes this ? It looked like a pretty dramatic failure. The splines looked clean and good right up to the failure where they were almost completely smoothed down.
I've seen coupler splines that get "cupped" before they fail but this didn't look like they went through that.
Also both electric shifts I took apart had the water pump impeller housings broken to pieces. Is this related or part of a different issue?
The main reason to ask : Is there a certain way to grease them or maintenance to do so this won't happen ? Those puppies are expensive !
