I've got an '89 OMC 4.3L cobra. It has started to take several tries to start, in that the first couple of times I turn the key nothing happens, then it will start. I've searched the forums, found several relevent threads, and think I'm ok as to a plan to diagnose and hopefully fix the problem.<br /><br />I've checked the battery, now I'm cleaning connections starting from battery going back to starter, solenoid, etc. I noticed that one of my manifold petcocks drains right on top of the starter/ solenoid. In the past I just opened it up, let it drain, and then pumped all of the water out of the bilge when done. (Think I'll try to rig some type of funnel and hosing to drain directly out of the boat in the future).<br /><br />But my question is should I coat each of the connections to starter, solenoid, etc. with liquid electrical tape to waterproof? Any problem with getting the stuff off when you have to take something apart in the future?
