bob johnson
Thread starter- Joined
- Feb 25, 2009
- 4,306
discovered I lost spark after running a short while and throttling down...
happend three times in three days...last time would could not get the motor started again and eventually had nothing at my key switch( would not crank over)
battery charged
so since the motor was under warranty, i took it back
the guys mechanic says my harness from the controls to the motor is bad.
because he said he plugged in his test control and the motor started up
while mine did nothing
BUT..when i had my problems after the motor died on the water...the motor cranked over fine....but there was no spark( used a spark tester right there on the water, because I figured it would happen again)
now how can my harness be bad to not allow spark, but allow the motor to crank over?
can a wire in the harness or a connection between some plugs go bad , so that the motor still cranks, but no connection is allowed to give the motor spark?????
seems fishy to me
he tells me that I have a bad connector and that it is broken on both plugs that fit together....
that was the issue.
I know it is hard to follow, because things got worse over a few days and the Problem metamorphosised from just loosing spark to not even cranking over.
but now the mechanic is saying they were all caused by a bad connection...
IN MY HARNESS...thus I have to pay for his labor to fix the issue and it isnt covered under the motor warranty.
if it is the facts, then i dont have an issue...just seems fishy, the connection turned on its problem and turned it off three times over three days...
funny the systems check lights all worked and the horn sounded and the four lights on the tach went off one by one...
but the starter would not crank
thanks
bob
battery charged
seems fishy to me
that was the issue.
thanks
bob
