Scott Chinsota
Thread starter- Joined
- Apr 18, 2011
- 216
was running fine. not great, not bad. but I knew the timing needed set. I used a timing light to set to spec at wot. this was done with throttle cable disconnected and both plug wires grounded. advance tied to stop and switch wedged to allow cranking. switch being the wont engage starter when past "start" on throttle lever. so, timing set @19 deg at WOT,
I held the throttle (linkage) at wide open position and adjusted control lever to approx WOT, then adjusted trunnion on engine end of throttle cable. this was just to get it close, not an attempt at proper adjustment. now i just keep blowing fuses. I didn't do anything to fry anything. I am baffeled. anyone have any ideas?
Thanks, Scott
btw...1971 50 hp 501173s evinrude lark with pushbutton remote.
Thanks, Scott
