davemoore
Thread starter- Joined
- Jul 7, 2009
- 96
While out on the lake Thursday afternoon, I started up the motor to move to a different spot and when I went to about 3/4 throttle, the engine began to bog down like it wasn't getting any fuel. I pulled back to about 1/4 throttle and it ran fine. I throttled up again, slowly, and it seemed ok, until I pressed the trim switch to bring her up, and it cut out again. I began watching the gauges and pressing the switch, and noticed the RPM's drop slightly, and the voltage drop (on the depth finder, which is much more accurate) every time I pressed the switch. Then I started trying other things - like the bilge pump - that draw lots of power and it did the same thing... like the voltage is dropping too low to properly charge the coil.
I usually have somewhere around 14-16 volts while running, but have been noticing less recently, and on this day, I was in the 11.5 range. At one point in the nights before, while using a hand-held spotlight, I noticed it drop to 10.5.
I'm not sure if my charging system is going, or if it's just a battery finally going. I don't know how old the battery is - we bought it with the boat.
What can I do to test the charging system? If it is the stator or regulator, I think I want to change to an alternator, right?
Thanks for any help.
Dave
Dave
