MASTER Brian
Thread starter- Joined
- Mar 26, 2006
- 738
I recently wired up a stereo and a 12v power outlet. I believe I ran the ground from the 12v and the stereo to the negative battery terminal and I ran the secondary, always hot, power from the radio to the positive termal. The main, non constant, power from radio and the hot wire from the 12v power I tapped into the fuse panel for my other 12v power outlet.
The radio seems to work fine, as does the 12v power when I plug my mp3 player into the outlet, but when I plug my spotlight into either 12v outlet, it doesn't come on and my radio turns off.
I had also wired in a dome light in the glove box, which is where I installed the radio and the 2nd 12v outlet. The dome light has an on/auto/off, which I was hoping I could take advantage of all settings, but it also gave me issues. I was trying to pull the "on" hot wire from the wiring from the radio and the "auto" and the "ground" wire from under the dash at the interior light switch. I finally gave up on using the "on" feature on the dome light because it gave me problems as well. I can't remember, but it may have kicked off the radio as well. But the light works fine when I turn on my boats interior lights and the way it's wired, using only 2 wires tied directly to the factory/interior lights.
What is most likely my problem?? Is it possible the spotlight draws too many amps? I have 2) 10 amp fuses feeding my radio. There are 2 because one is on back of the radio and the other is in my fuse box. Is it possible the cigarette lighter is wired up backwards? It has a red and black wire, I can't believe I would have crossed the 2.
