I have a 78 ebbtide with 4cyl gm andmercruiser outdrive. alot of times you can turn the engine over and it wont start, you can jiggle the shifter and it will start up. most of the time before boating you can spray wd 40 on what i was told is some kind of interruptor switch on the back of motor almost on the transome. if you dont spray the switch it kills the motor. Is there any wayto clean the switch adjust it or just buy a new one. I appreciate any input you guys might have.
