I have a 1991 Prowler Bass Boat by Sunbird. Leaving Michigan for Texas everything worked. Got to Texas and nothing works--it's as if the battery isn't hooked up. Checked the fuses, replaced 2. Had a mechanic friend check it out and he said there was power on every toggle switch, but still nothing works. When I direct line the aerator, it works--same with the bilge pump. Am replacing the four toggle switches, but is there anything else I can check before I have to take it to an electrical guy? I'm leaving for vacation in 3 weeks and sure need to find out what's going on.<br />thanks<br />blt
