Mike Langianese
- Joined
- Aug 3, 2003
- 122
1992150 hp Evinrude<br /><br />Spayed corrosion block around starter solenoid, must have shorted out connections. Manual states that all connections should have OMC black dip applied, found all were bare/uncoated connections.
<br /><br />Started engine, smoke from around starter solenoid area, turned off engine.<br />Entire area HOT to the touch, after cooling, NO RESPONSE when key turned when attempt to start.<br /><br />Removed starter, Solenoid tests erratic, from 14.5---8.9 M-ohms to O-ohms. <br />Original starter always turned slow, will replace both the starter and solenoid.<br /><br />Anything else to check? Gear is DRY when reinstalling what is the recommended lube?<br /><br />Thanks for your advice<br /><br />Mike
