I need some help. I have a alumniun hual boat and the hual is grounded can some one tell me if that can cause electricious on the boat? If I disconnect the ground at the motor the 12volt reading goes away should
the outboard motor be ground to the haul? The volt reading I is 12 volts from the poitive post on the battery to the boat haul.
Thanks the help
Thanks the help
