Electronic Ignition Component Compatibility
ezez
I know this has been covered in the past but would like some reassurance. On motors with the Prestolite (blue) ignition, are all components (stator, trigger, coils, CDI boxes) interchangeable from a 4 cylinder (120/125HP) to a 3 cylinder (85/90HP) motors?
Thanks in advance!
Frank Acampora
Re: Electronic Ignition Component Compatibility
Trigger--NO. All other components, yes. (with the possibility of some slight rewiring , depending upon whether both are terminal board or quick connect systems.)
ezez
Frank, as usual thank you for the info. :D
