jakehorton15
Thread starter- Joined
- Feb 16, 2014
- 66
I'm about to go ahead and order a Pertronix Ignitor and Flamethrower kit to install in my 1990 3.0 Mercruiser to replace the points system, I'm tired of having to change them and tired of the long sluggish starts so I figured Id give it a try after all Ive read about them.
I just wanted to clarify about the coil whether I should go with the 1.5ohm or the 3ohm. Im under the impression (and could be wrong) that both will work but with the 3ohm I will have to bypass the resistor and wire it to the choke to receive the full 12volts needed. Or I can go with the 1.5ohm and just wire it up as is with no alterations. Do I have my facts right or am I off?
The models I think I need are:
Ignitor 1146a for 4cyl Delco
FlameThrower 40111 1.5ohm epoxy filled
Do these model numbers seem right to those of you that have done this modification before? I just wanted to make sure I had my information correct before placing any orders. Thanks, Jake.
