Electronic trim wont work (FIXED)
bigshrimpn
1998, 115, merc mariner
Trim was working fine all day when I went to trim it up after I got it on the trailer nada. Both the control on the throtle and the motor bear no result, I can here a clickling noise coming from the two celonoids when I press up or down. Any advice would be greatly appreaciated.
Thanks, Dave
RRitt
Re: Electronic trim wont work
use a voltmeter to check relay output. If the relays are delivering voltage to motor then the motor either spins or is broken.
bigshrimpn
Problem solved, I had 4 grounds going to one point I split them up and all seems to work fine
Jacket4life
Re: Electronic trim wont work (FIXED)
Cool!
How did you edit the title of your post?!!?
Tried to do with mine and failed!
bigshrimpn
maybe its a new format I just hit edit and it let me change the title
