Calling the Elgin guru's or anyone that has ever done it.
working on a 49-51 Elgin 401, 2.5hp
Any tricks to getting the lower unit/ water pump housing off?
Already have the prop shaft housing removed, Drive shaft gear clip removed, and of course the 1, 1/4 bolt removed. Have soaked for weeks with various solvents, and gone around mating surface with fine edge chisel. There is a threaded plug on shaft housing just above lower unit that I have also removed, at the bottom appears to be something brass (water tube if I had to guess), but no obvious way of removing. Is there some unseen something keeping the lower unit from removing?
All bigger OB's I've ever worked on the lower pulls off after the lower bolts are removed and wrst case a shift linkage unbolted, but this tiny motor has no shifter.
