ELPTO 50 starting procedure
oldjeep
Any special starting procedure for a ELPTO 50 2 stroke? Dad says his is hard to start, he pushes the key to choke while starting. Last time I ran the boat I had to give it a little more gas by slipping it into neutral.
vance14
Re: ELPTO 50 starting procedure
I have the 3cyl 40,the procedure I us is first to prime the bulb,turn on the ignition,push in key to activate the enricher and slowly count to 3 and release,then turn the key to start.it almost always starts in about 3 turns and if not release the starter and hit the enricher for a count of 2.I never use the throttle as it will flood the engine.If the weather is cold i will hold the key in for an extra second.I used to have the same problem as you but my dealer told me this was the best way to start it.
vance
