alumacraft74
Thread starter- Joined
- Jun 21, 2007
- 11
New to site ,hope ya'll can help.Ihave a "74 Evinrude 25hp #25402.I have had this problem since I purchased a year ago.I can put the boat in the lake,start it up,runs great.I can idle all day,but as soon as I go wide open throttle,which runs fine always at wot,and try to idle back down such as coming to shore or ramp it starts dropping a cylinder.I can go back to WOT and its fine but when I try to idle it loses a cylinder and eventually both because it dies,and wont start back.Let it sit 30min to 1 hr. and it will start right up and idle.I have totally rebuilt carb several times(soak overnite and blow passages with air hose),New coils on both cylinders,plugs,Points and condensor gapped at .020,and new Driver coil.Always the same problem and cant figure what it is.I would greatly appreciate anyone with some suggestions. Thanks, Chad PS. Compression 120# in both cylinders
