embarassing question 86 J8
cemiiii
I cleaned my carb and i can't remember which hose goes to which nipple. One leads into the primer, the other comes from the fuel pump.
Which one goes to the lower nipple at the bottom of the float chamber?
I can't find a viable answer in my manual.
thank you, chris
tashasdaddy
Re: embarassing question 86 J8
fuel pump line goes to float chamber.
cemiiii
now i'm not doubting your experience on this but.......when i connect the fuel line to the bottom nipple on the float chamber and the primer line to the nipple on the carb body just above the float chamber, and then squeeze the fuel bulb, gas comes gushing out of the carb everywhere, the bulb won't firm and the primer won't work.
If I reverse them, there are no leaks and the primer works fine and the bulb firms.
Unfortunately neither position is allowing the engine to fire and now i'm really confused.
chris
cemiiii
yeah,seamen apprentice shementis!, more like the king of outboardwreckers extraordinare!
